It is currently Fri Aug 15, 2025 7:31 am
PostPosted: Fri Nov 07, 2014 9:09 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
The truss rod slot in my kit-guitar's neck is shallow by roughly 1/32". I need to remove at least that much material so the truss rod doesn't try to hold the fretboard off the neck. Add another 1/32" for the shim between the truss rod and the fingerboard. I found an Amana 'dado clean out router bit', which has a ball bearing that could guide the cutter so as to not inadvertently widen the slot (router bit is 3/8" in diameter, the slot is 7/16" wide), to deepen the slot, running it up one side and down the other of the truss rod slot. If there's an alternate idea that doesn't involve a router and will end up with solid truss rod contact in the slot I'd love to get enlightened. I have great respect for Porter-Cable's ability to overdo the widening thing if I don't have some kind of guide. According to Amana's dimensions, I'll have 1/16" of the bearing riding on the slot edge as I massage the slot bottom.
Thanks, folks. Very much.
Peter Havriluk
PostPosted: Sat Nov 08, 2014 1:23 am
Last Name: Beaver
City: Lake Forest
What you are planning will most likely do the trick.
Where did you get the kit from? I was wondering because I was thinking if it was me I'd give them a call before I bought a tool that I may never use again. Seems like they ought to make the neck work for you on their nickel.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 08, 2014 7:03 am
post pics
PostPosted: Sat Nov 08, 2014 8:04 am
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Not inexpensive, but exactly what you need.
http://www.leevalley.com/en/wood/page.a ... 1182,48945
Good luck
PostPosted: Sat Nov 08, 2014 8:38 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
Go the safer route. Get an appropriate width SHARP chisel and scrape it to the correct depth.
PostPosted: Sat Nov 08, 2014 8:45 am
"Go the safer route. Get an appropriate width SHARP chisel and scrape it to the correct depth."
+1
PostPosted: Sat Nov 08, 2014 11:44 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Thanks, folks. I'll see about putting a chisel to work.
Peter Havriluk
PostPosted: Sun Nov 09, 2014 1:27 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I agree with a hand tool approach, but without a burred edge, I'm not sure how well a sharp chisel will perform as a scraper. I made a round scraper for deepening truss rod channels from an old screwdriver having a hardened steel shaft of appropriate diameter. Cut off the end with a hacksaw, file the end smooth, put in vice and burr over the edge by striking end with a hammer. Presto, round scraper with own handle. Quickly deepens channel on the draw stroke. Not suitable for all truss rods over entire length, but will do the lion's share of the work for most.
PostPosted: Sun Nov 09, 2014 9:44 am
First name: Tom
City: Portsmouth
Tim,
Hold a sharp chisel at an approximate 70-75 degrees to the surface and pull towards yourself. No burr required. I'd guess that after ten strokes or so on a mahogany slotted neck you could easily get 1/32nd out of the slot.
Best regards,
Tom
PostPosted: Sun Nov 09, 2014 10:52 am
First name: peter
Last Name: havriluk
City: granby
State: ct
I did, and that's just what happened. Nice way to work around a non-problem. Thanks!
Peter Havriluk
PostPosted: Sun Nov 09, 2014 4:35 pm
First name: Tom
Last Name: West
State: Nova Scotia
http://www.theunpluggedwoodshop.com/wp- ... ogue-3.jpg
Surely everyone has one of these tucked away in their toolbox.........???
Tom
PostPosted: Sun Nov 09, 2014 7:08 pm
Tom West wrote:
http://www.theunpluggedwoodshop.com/wp-content/uploads/2014/08/card-catalogue-3.jpg
Tom
I have a small one and a very useful tool is is.
Users browsing this forum: bobgramann and 12 guests
